Discuss Which combi boiler is best in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ThanksFor me I would be looking at a Vaillant or an ATAG
ThanksAnother for Viessmann also the Ideal Logic plus...
Make sure a filter is fitted to the heating, a scale reduced is fitted on the cold mains into the boiler, the system is flushed properly an inhibitor is put into the system, the boiler is registered with gas safe and not just the boiler manufacturer that it is serviced every year otherwise the warranty is worth nothing.Thanks for your input and as you say all have preferences but I didn’t want her to get a boiler that proves unreliable and the old buy cheap buy twice kick in. This has now given a bit of insight and if we look for a good boiler that also gives a lengthy warranty we should be ok.
just to throw a spanner into the works Building reg are changing in April for combi boilers so to avoid extra expense fit one B4 thenHi harvest, what type of scale reducer do you recommend she get.
What’s some person changing this timejust to throw a spanner into the works Building reg are changing in April for combi boilers so to avoid extra expense fit one B4 then
have you fitted any of the new range of Vokera boilers ? you seem to think they are a joke, just wounding what your basing your comment onVokera? Ravenheat? Lol
You need to get up to speed on the forth coming changes if your involved with installs it will affect youWhat’s some person changing this time
And people still moan about trv’s ...hows it going to be monitored...
Do you mean the efficiency additions, controls etc or something else?You need to get up to speed on the forth coming changes if your involved with installs it will affect you
You Don't like them then ? bet your a Worcester man ! Strange fitted a few over the last 4 mths never had any problems what model Vokera did you fit ? And no I don't only fit Vokera this Mth its been Ideal unitsYeah I’ve fitted s few. I’m basing my comment on the fact that they are ****. Lol
Air intake tends to come off in transit and won’t run with it off. The combustion door is terrible, the seals are terrible. I had a vertical flue leak into the boiler, the actual flue not my joints. Commissioning is old fashioned. Plastic components, **** ‘O’ rings etc etc etc
I apologise mr moderator, Thankyou for correcting my French.What’s some person changing this time
HAha yeah used to be a Worcester man, but find them too complicated, too expensive, too plastic, too hard to work on and too many common faults. I mainly fit Baxi nowYou Don't like them then ? bet your a Worcester man ! Strange fitted a few over the last 4 mths never had any problems what model Vokera did you fit ? And no I don't only fit Vokera this Mth its been Ideal units
If I am honest as long as they fit one it doesn’t much matter. But I fit Fernox inline scale reducers but compression not push fit as I have had a couple of push fits leakHi harvest, what type of scale reducer do you recommend she get.
Reply to Which combi boiler is best in the Plumbing Jobs | The Job-board area at PlumbersForums.net
