Discuss Whistle sound from behind wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Alright chaps!
Could anyone tell me what is causing the noise in the video below?
It's coming from my neighbour's side of the wall so I cannot easily investigate. But it seems to be relating to the pipes near here kitchen sink.
It occurs randomly over the course of day & night.
Thanks in advance!
Over zealous kettle??? But seriously, it could be her kitchen tap, it could be the incoming mains with maybe some debris or a loose part in the stop tap. Could also be sound transmitting back down the pipework from where the ball cock fills her CWSC in the loft
Haha I wish it was as simple as a kettle! She actually let me into her flat to investigate and I couldn’t make it happen when I was there and I tried using her taps.
The stop tap is a possibility I suppose. I actually tried moving that as well but it was stuck solid. Thoughts?
Alright chaps!
Thanks in advance!
I’ve had that before turned out to be an isolator hidden inside boxing and was only opened a fraction so was causing restriction causing a flow noise
A ghost with a whistle lol had a similar problem in a factory only heard at night it was a leak on a 2" pipe below the ground on the mains when no one was using the water at night the mains pressure increased and was making the sound had the security men freaked out lol
Reply to Whistle sound from behind wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
