Discuss Why are gas safe engineers reluctant to service my Netaheat Profile? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ric2013
I was thinking about the landlord bashing that went on in another thread re. the fact that the landlord had never had his boiler actually serviced.
It occurred to me that I am similarly guilty. I still haven't found a house I wish to buy in Wales and my house in Essex is therefore rented out (usually) and I rent over here. Inconvenient, but that's how it seems to work right now.
Over the years, even while living in Essex, I NEVER had my Potterton Netaheat Profile properly serviced because attitude of gas installers seems to be that the old boilers aren't really worth servicing - 'you just end up shifting the dirt around' - so, while the casing comes off annually for the GSR guy to have a look at it, nothing gets done unless something goes wrong. Worse, one CORGI guy (as it was then - he was later struck off the CORGI register) used to run a wire bottle brush thing around the heat exchanger and then leave the dirt inside the casing!
I would love for someone to clean everything properly as per Potterton's recommendations, but when you have someone you trust and you ask him to service the appliance and he tells you not to bother, what would you do? At least the guy I use at the moment I can trust not to break the boiler - which is more than I can say about some of the gas installers I have met over the years.
Some Landlords ARE cheapskates, but ultimately we have to be able to trust the GSR people to provide good advice (and I wonder if that was what happened to the other person who came on this forum moaning about the silicone seal on the Vaillant). For me, I'm not cheap - I was one of the first landlords to fit a CO alarm, before it was even a recommendation, and the house has interlinked smoke/heat alarms, fitted well before smoke alrams became compulsary, but short of cleaning out the boiler myself... but, of course, I'm not competent to do that.
Would people on here disagree that a Netaheat Profile ain't worth servicing? For what it's worth, the house is currently empty, so no one is at risk.
Not in the 8 years I've owned the house. In fairness, though, the seal does look to be as good as new.
Every gas appliance should be regularly maintained with no exceptions tbh
i suggest you find a better gsr engineer,the profile is a positive pressure case seal so i would hope whoever services it knows what they are doing
Reply to Why are gas safe engineers reluctant to service my Netaheat Profile? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a gas warning notice for at risk as the outside wall meter box has been drilled through for the gas pipe to go horizontal straight to the boiler. The...
I currently live in a 4 bed end of terrace victorian house, with 11 radiators and two towel rails. Currently have installed a 6kw potterton gold electric boiler, which heats a hot water cylinder and provides heating to the radiators. My electricity usage is extremely high and killing me...
2K
This is the background. I noticed a smell of oil in a small enuite that adjoins my boiler house and went out to boiler house and oil tank to have a look. I could not find any odours of oil anywhere so assumed it had come in window, ie you can get a smell of oil from tank, near the outlet pipe...
3K
  • Locked
Our client, SJH Building Services Ltd, specialises in heating, ventilation, air conditioning and refrigeration with electrical services for residential, commercial and industrial sectors. They are offering wide ranges of air conditioning and refrigeration equipment and products, working...
1K
Catherine Dick was prosecuted by Halton Borough Council Trading Standards. The 33-year-old from Clayton Crescent in Runcorn, pleaded guilty to two offences of making false claims when she appeared at Chester Crown Court. Dick, trading as ACN Heating and Plumbing Services of Clayton Crescent...
2K
