Discuss Why would it be wrong to run a shower pump on 15mm? in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Ric2013
    Ric2013 Plumber
    Apart from the obvious answer which is this would not be to manufacturer's instructions and would void any warranty.
    I was having a discussion the other day with a builder who wanted to run the cold side of a 1.5Bar twin-impeller pump from a dedicated cold distributing pipe in 15mm. He claims this is what he has always done in the past and it works (I would imagine this is true, to some degree).
    I have looked at the MI, which state that the suction side of the pump should be 22mm and reduce to 15 close to the 15mm tails supplied with the pump. Common logic would be that 22 is required because the suction side is gravity, but, while I know 15mm would be wrong, I'm trying to understand WHY it would be wrong.
    My feeling is that, since 15mm on the delivery side of the pump is considered sufficient, and that the flow rate will be the same on both suction and delivery sides, 15mm is enough for flow on suction side. However, I would imagine the risk is cavitation, leading to premature failure of the pump impeller and possible the pipework or fittings on the suction side of the pump.
    Do people feel my understanding is correct?
    Thank you,
    R
  2. rpm
    rpm Trusted Plumber
    Many pumps insist on a larger inlet and a smaller outlet, cavitation is basically trapped air becoming very hot and popping / exploding.
    • Like Like x 1
  3. king of pipes
    I have done plenty in 15mm not any dramas.
    • Like Like x 1
  4. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    Never done one myself in 15mm always have the feeds in 22mm, but I have replaced loads of existing ones that have both feeds in 15mm and they have been running for years. But best practice is definitely 22mm. I always recommend the pipes are upgraded
    • Like Like x 1
    • Useful Useful x 1
  5. ShaunCorbs
    I've done it but only if there a short run to the pump
    • Agree Agree x 1
    • Useful Useful x 1
  6. Harvest Fields
    Maybe if the CWS was straight above the cylinder. But I would still have a bad nights sleep:p:p:p
    • Useful Useful x 1
  7. townfanjon
    townfanjon Trusted Plumber GSR
    I thought that was because you followed Villa lol
    • Funny Funny x 2
  8. king of pipes
    Sleep like a baby ha ha , mind you i didnt last night have had a git of a job this week a boiler swap cylinder change and controls upgrade , electrian wired something wrong and i had air and circulation issues but got it sorted today so happy days , sacked work off tomorrow having a slack day paperwork and catching up with people
    • Winner Winner x 1
    • Optimistic Optimistic x 1
  9. ShaunCorbs
    :D until someone phones in saying ive got water everywhere
    • Like Like x 1
    • Winner Winner x 1
  10. mache
    mache Active Member
    not quite correct description. Cavitation occurs when pump impeller or sharp edge even causes a low pressure area in which a vacuum pocket forms. When that pocket collapses the violet energy change can rip material off the surface of any material it is in contact with. But I do agree that a restricted protracted inlet (e.g. full length of 15mm run) could increase the chance of cavitation occurring.
    • Like Like x 1
  11. king of pipes
    Not tomorrow shauny had enough this week bud, mind you got a fancy rad to fit saturday so my weeks not over yet whats your week been like ?
    Nice one mache learn something new every day
  12. Harvest Fields
    Cheeky;)think we will do ok this season. Ow though. Still sacked my season ticket off though.
    • Like Like x 2
  13. ShaunCorbs
    busy
    finished off a cloak room sink / vanity 2 cabinets new cc toilet shower head replacement
    now starting a full down stairs bathroom
    • Like Like x 1
  14. Harvest Fields
    At least you don't have to cart the bath upstairs:)
  15. ShaunCorbs
    no bath and already done the upsairs one :D
    • Like Like x 2
Loading...
Similar Threads - wrong shower pump Forum Date
Central heating can hear a lot of air. Pipe wrong? Pics Plumbers Arms Mar 27, 2018
Advise please on shower mixer Valves & Taps Saturday at 5:31 PM
