Discuss Wood boiler ch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Rosswaitt
Living in france and my wood burning furnance for the central heating only , has just split the jacket !
it had been fitted in a closed curcuit without auto matic quench system ! Not by me !
Reason failed pump
Having great difficulty finding a 50 kW + wood boiler with quench system ? Does any one know of one suitable for a closed system
or do I change it all to a open system
thoughts please
Before making an informed comment, a site visit to your chateau is necessary.
10 days in June would be nice. Me, the wife and the wife's sister. Unless I can leave the wife at home.
Returning to your question, what feed do you have to the furnace other than throwing in 15 Kilo of logs every hour?
Hi,Rosswaitt,
With only me responding, I'll start, this time, by saying welcome to the forum.
The lack of response will be that most of us lack the expertise to comment on a system of that type and output. At lest one regular,based in Northern Ireland will be able to help, and if you expand on details of what you have and what you're heating, it should encourage an informed response.
Hi Rosswaitt, welcome to the Forum. Hope you enjoy it here. Lots of free advice!
When you say "wood burning furnace" so you mean log boiler? If so there are plenty that run on sealed systems such as ETA, Froling, Guntamatic etc. Some more information may help us further!
thank you
the re[placement boiler need to run on a closed system.
at the moment the old system ran at 1.5 bar
it is in a small chateau with 26 radiators on 3 floors hence the need for 50kw
whilst i would like to be able to afford a ventilated automatic boiler i cant afford it
looking serious at VIADrUS U26 the problem is it has 2" BSP inlet and outlet and all my pipework is 28mm ! can i reduce this safely ?
At the moment I don't have enough information to add much further. If it is a log gasification boiler as a rule of thumb you will need a buffer with 50L of storage for every KW of heat input. That is a mimimum 2500L buffer tank to start with. You then need back end protection for the boiler, a safety PRV set capable of high discharge should something go wrong, an expansion vessel sized to something around 3000L system volume etc. This is not a DIY job to be fair.
OP originally spoke of 50Kw+ wood boiler. Be aware U26 is max @46Kw for wood although high outputs can be achieved with coke. As above, this is not a DIY job.
I was looking at just a non gasification boiler!
I have found one with cooling coil
I was hoping out with the old in with the new but this time with the cooling coil
Reply to Wood boiler ch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My central heating is run off a heat pump ( air to water ) quite expensive to run , So I’m plainning to fit a wood burning with a back boiler to connect to the heating system, So while the wood burning on during winter months it will stop the heat pump for working hard Or not all all . My...
I'm looking for a heating engineers/old school plumber to put in a Combi boiler (possibly Intergas) replacing very old open vent system in parallel with a wood burning stove with a back boiler (ESSE Bakeheart) as back up and alternative. I know this relies on two radiator systems. Combi for...
1K
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem could be. We have a biomass boiler and stratification tank set up and recently had an issue with boiler pressure dropping off when the system was cold...
C
My parents house has a wood burning stove that is also connected to the central heating ( they have radiators and used to have an old boiler which they took out and replaced with the wood burner ) so the wood burner can also heat water which can then be pumped round the rads and works fine when...
1K
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this could be as a result of us noticing the sound more when there is less environmental noise). Unfortunately, it is severely disrupting our sleep, so we...
