Discuss Worcester 24Sbi overheat problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
fredflintstone
Can anybody help. my boiler has decided not to work!! When I turn on from cold the normal start up process works, pump starts, fan starts, ignition, 10 seconds later burner goes out steam comes out from the vent on top. I have hot water down to the pump out of the bottom the pipe doesnt seem to be as hot. Is it a pump problem!! I had the front of the pump assy off impellor looks ok and turns freely but their is quite a bit of float in the shaft(does this mean its ok??) this is the second pump in eight years. The pipe from the pump goes to a mid position valve, could the problem be their?
I am hoping it is a pump problem as this is the easiest to fix I think?
Any suggestions more than welcome as my five kids are starting to understand what is was like to live in the dark ages!
Reply to Worcester 24Sbi overheat problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
