Discuss Worcester 24Si II Boiler - Red Light flashing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sparks1
My 92 year old Gran has a Worcester 24Si II Boiler for about 9 years and when I switch the heating on after about 30 secs the Red Light starts flashing fast. The hot water works fine its just when I try to switch heating on.
See pictures attached.
When I switch it off and reset biker it is fine for the hot water only. But whenever I try and put the heating on it displays the red lightning flashing as if their is a fault or it is overheating?
Can anyone help and advise what the issue may be?
Also is it worth getting fixed or should we look at getting a new boiler?
Much appreciated if any advice is given.
Me personally if you can afford I would price a new boiler up, they wernt the best from new and you don't want it going down in the middle of winter
Normally they only last 12 years maximum
With these it could be just a small part, But they are known for PCB fault and that is quite an expensive fix ÂŁ200. + get Worcester out on a fixed price repair
Reply to Worcester 24Si II Boiler - Red Light flashing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
My Worcester Combi Boiler is not working, instead the display flashes on and off repeatedly, as shown in <a href=" View: https://youtu.be/Touvx2c3RJE ">this video</a> I took when turning it back on this morning (it had been off overnight) - it shows the behaviour, but if that fails, all the...
J
Hello, I have a Bosch 35CDi, and today found all the lights flashing on the front. Normally I can reset the boiler, but this did not work. There isn't an error code, since even the error code display is flashing. I have searched the internet but cannot see this problem elsewhere, since every...
Deleted member 120897
Hi, whenever my Gloworm 18r is on even if I leave it on non-stop for 6 hours the flame symbol for the burner never switches off and the radiator icon never stops flashing implying the rads are calling for more heat, even though they're all red hot and have been for hours, is this a fault or just...
A
Gloworm FF50 both the reset and burner lights are flashing and just buzzing, not firing up. Currently no hot water or heating, everything was working ok earlier today, then just suddenly stopped.
Hello, Newly moved into a house with a mains fed cylinder system. I've never had one before and struggling to get it working. When I turn either heating or water off at the timing unit, the other works fine. Eg, with heating off, water works and vica versa. The indicator lights are solid blue...
