Discuss worcester 38cdi come giving EA fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Gasmk1
called this morning had aquick look change electrodes as ionisation probe was quite burnt away, but went off again later calling back anything i should look for thats obvious ( customer has not had it serviced regulatrly so the warranty is void even though it had 6 years)
Distance right ? Did it fire etc ?
i changed the electrodes for a new set the updated version as i carry a set with me usually, also checked and cleaned condensate trap. yes it fired ok checked it fired for heating and hot water but appparently when the homeowners son had a shower later on it went off again. will carry out more tests when i go back. just wondered if there is anything obvious
Bearing plate sticking?
Had a few do this recently
Without any more info / tests no
Did it fault before you changed the probes ?
The fault was why I visited the job boilers been in about 4 years only had one service. Gas supply is ok like I said I will be going back to carry out those checks just wondered if there was anything obvious that I might miss. Seeing as how EA is such a vague fault
Thanks forgot about bearing plate this should give me iffy C O readings if it is sticking, I will pick one up just in case
The Ines I have had are working fine but sometimes it sticks and fails to light
I believe you need new gaskets if opening it up
Dont think this should be being discussed on the open forum guys can Dan Or Luo move it to to the registerd forum cheers kop
Reply to worcester 38cdi come giving EA fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
