Discuss Worcester Danesmoor oil burner. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys I was hoping someone could let me know what type of oil burner this is on a worcester danesmoor. I've spoke to worcester and they didn't know. I've looked high and low for any data plate/info with no joy so I've come to the conclusion that it's disappeared with age.
I would say an old bentone oil burner but can't be sure on aodel number. I'm sure someone will point you in the right direction tho
No it is not Bentone burner, it is definitely a Selectos burner.
The blue sight glass for looking in at ignition/flame is a giveaway.
The name plate should be the sticker on top of burner in photo.
I have worked on Selectos burners all my working life and an older similar version was on Thorn ODY downdraft boilers, built in early to late 70s
Yours is much newer type - possibly 25 - 30 years old.
The main parts to that burner are very standard, but it is a tricky burner to work on and adjust to give proper analyser readings.
Reply to Worcester Danesmoor oil burner. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
got new oil and tried to start my reillo g3b oil burner ,when it idnt fire and went to lockout i bleed the pump and check the nozzle ,and eventually took apart the pump to find lots of black oil slug around the oil pump.so i cleaned all the stuff of and cleaned through the pump and the only...
Hi, I wonder if anyone can help. I have a Worcester Oil Heatlslave 20/25 that has started making a fairly loud knocking noise and the the pressure gauge flicks a little when the noise thumps. The hot water still works, I've turned off the heating for the time being. Any ideas on what the...
Hey guys in the know. I have paid for a heating and plumbing contract and had to pay my excess 3 times for the same thing still not fixed. The issue is quite simple to repair not sure why any one of the 2 plumbers could not fix it. Why am I paying for cover. The auto air vents in part of the...
Hi I'm going to be fitting a tap like this one: And just wanted to check that this is the correct part for connecting to 15mm copper pipe using compression: https://www.NoLinkingToThis/p/flomasta-compression-straight-tap-connector-15mm-x-1-2-/58294 If not, please could someone let me know...
Hi guys. I've been running an UFH installation/ repair business for 7 years now and one of my main frustrations is finding the parts for the UFH. I've got quite good at it over the years being able to recognise the manifold brand and generation by just looking at it but then I have to go through...
