Discuss Worcester greenstar intermittent fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hammers4spanner
Subscribed
Attended this on friday heating and hotwater cut out after about two minutes , slow flash on blue light mainly on.
Reset boiler and same same, replaced flue stat and temp stat but still same fault .
What's the gas pressure?
Could the heat exchanger be blocked ?
I’ve added the fault diagram.
I checked most if that i thought hex could be blocked as when put it in service mode it locked out quick sharp. Mentioned it to customer and she went nuts as boilers only about 6 years old lol,,,,,,oh the joy
Reply to Worcester greenstar intermittent fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
