Discuss Worcester heatslave 2 exterior combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
hi guys I went to breakdown today. The boiler fault code was 219 e9 saftey temperture too high? How do you fix this and would this happen? I reset it and everything is bk to normal bk then it went bk to the fault code.
Pump working ?
I know the previous plumber charge the expansion vessel as it had been activated. Any other suggestions please
Dirty system
Temp sensor on its way out
Diverter not moving fully to heating etc
Heat can't get away so start one end and start checking things off
Reply to Worcester heatslave 2 exterior combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
