Discuss Worcester Hi Flow 400 water or heat not both in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All
I have a Worcester Bosch Hi Flow 400 RSF Gas Boiler
When the heating is turned off , and hot water on, the boiler fires and gives hot water.
When the water is turned off ,and heat on , the boiler fires and gives heat.
When both turned on, boiler will not fire up.
Any ideas please.
Rob
Best option is to get a local gas safe engy out to check it over
Hi Shaun , Thanks for the response,
I am a simple plumber, My good mate who is a Gas Safe registered, heating engineer, at first view, does not know what the problem is. So we thought it may be a good idea to post on this forum in case any of you super technical guys out there had experienced anything similar and hopefully get a heads up and some ideas.
It seems not, But thanks anyway.
Morning. You would get a much faster response if your Gas safe mate had an account on here and had posted it for you. It is not that Shaun doesn't want to comment. It is the fact the we are not allowed to discuss gas safe issues with people who are not registered with the above mentioned governing body. Sorry.
Reply to Worcester Hi Flow 400 water or heat not both in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the outputs goes to a 2 port diverter prior to the Megaflo (I believe this is some safety feature). I have run into an intermittent problem where some...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always amazed at the water pressure so on the odd occasion that the water was only luke warm it was easily forgiven, but over time we have come to realise that...
Hi there, My boiler (Worcester Greenstar Ri) has started making a soft knocking noise when it turns on, and again a few times when it turns off. I've attached a short video of the sound. It isn't constant, it seems to happen within the first 10 mins of the boiler starting up, then you won't...
Hi all, I have a wallstar combi oil fired boiler. We got low on oil a couple of weeks ago but didn't run out. Since we've had our oil delivered the boiler won't fire up when hot taps are turned on so no hot water. The boiler fires up periodically to heat water but not when we turn on taps. I...
Boiler and Megalow mistery Hi, Just moved into a house from a flat and I have a couple of queries. We have a Worcester gas fired boiler - Greenstar Ri (in the kitchen on ground floor) and a megaflow (on the first floor) plus a small red tank that I do not know what it does. Heating is set to...
1K
