Discuss Worcester ri 24 service mode max wouldn't fire but blue flashing light 5 times in the Gas Safe Register Forum - Public Forum area at UKPlumbersForums.co.uk.
  1. Inverness
    Inverness Plumber GSR
    hi guys, went to carry out a service... went to high fire setting mode but nothing happened? Blue flashing light 5 times.. checked condensate not blocked.. flue good..
    Reset the thermostat knob but nothing happened. Standing gas pressure 25mb to the gas valve..
    When I put the heating on from the programmer the boiler fires up fine but I noticed the blue light still flashing but faster? I notice the heat exchanger was very hot to touch and making noises?
    I'm new gas engineer so be gentle.lol
  2. ShaunCorbs
    was the pump running?
  3. Inverness
    Yeah it was pulsating and the return pipe was getting warm.
  4. ShaunCorbs
    port valves open ?
    o and the 5 flashes means its in service mode
  5. Inverness
    Yeah the port valves open.
    I'm I right in saying, when nothing is calling for heat. And I turn the service dial to max shouldn't the boiler go to high fire?. Or do I need to go and call for the heating to cone on?
  6. ShaunCorbs
    pump wont run if you dont have anything on eg call
  7. Inverness
    Ok I'm confused now. I took off the cover and I rotated the knob that's concealed behind the Panel and rotated it to max as it was in the normal. The boiler started to flash but never fired up? Shouldn't the boiler fire up like the chimney sweep button on the other worcesters?
  8. ShaunCorbs
    did it have demand?
  9. Inverness
    No it didn't. I thought when you put it on max this would fire up the boiler?.
  10. ShaunCorbs
    no as no pump connected your thinking of a combi
  11. Inverness
    Alright so if I have a demand on then put it to max I'll be able to get a negative air pressure reading.
    I'm stupid
    • Like Like x 1
    • Agree Agree x 1
  12. Inverness
    Thanks Shaun
  13. ShaunCorbs
    :D
  14. king of pipes
    king of pipes Trusted Plumber GSR Top Contributor!!
    You need a external heat demand bud to get rid of the heat . Kop
  15. Bibbs118
    Bibbs118 GSR
    That negative fan test is bullshit, ive had it pass that test but need a full strip and clean, and fail that test but not need a strip and clean.
    Could just be me but i dont do that test, i remember when it came in and i find it proves nothing
    • Agree Agree x 1
    • Useful Useful x 1
Loading...
Similar Threads - Worcester service mode Forum Date
Worcester 28CDI Service Confusion.. Gas Safe Register Forum - Public Forum Sep 2, 2018
Worcester greenstar intermittent fault Gas Safe Registered Plumbers Only Yesterday at 7:07 PM
