Discuss Wras approved flexi? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I guess a flexi that is used on a toilet supply needs to be wras approved. Even though its not supplying drinking water. But incase the system experiences back flow. Am I correct?
Yes but tbh anything you supply/ fit should be wras approved
I just saw a 500mm flexi in screwfix one with an iso valve that isn't wras approved. Can't think why you'd want one with an iso valve on for a heating system.
Because it's a normal cold water one :D always pipe up expansion vessels in copper
And some people just don't care fitt anything
Reckon most expansion vessels I see have a flexi, thought it was the norm.
IMO , most wras gear is generally better quality rather than the normal Far East junk
Not wras approved though. Thus not suitable to put on the toilet feed? Need a longer one than 300mm.
Thanks is the above flexi not suitable to pipe a toilet up with, because its not wras approved. Cant see the purpose of it, when do you need a flexi with and iso valve on, on a heating system?
I would not use them on heating only on hot and cold supplies stick with the wras approved product generally better quality . cheers kop
Why do you need it that long ?
Have you tried BES? Do plumbing items need to be specifically WRAS approved? I thought that just meant they'd given someone in WRAS a backhander or sexual favours? What if it has a KIWA approval or suitable BS?
Reply to Wras approved flexi? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
