J
jims45
As zoning is now required in all new systems does this mean it is no longer practical to use a combi for a small installation,if viable has any one advice for setting out such a system.
Discuss Zoning with a combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
New builds with a floor space over 150m2 must have this area split into 2 (zoned). There must be an independent means of control for each zone.As zoning is now required in all new systems does this mean it is no longer practical to use a combi for a small installation,if viable has any one advice for setting out such a system.
Since when are combis for flat and one bed houses? A larger combi will easily suit your average 3 bed semi. Its only when you step upto the 4 kids, 3 bathrooms in operation scenario, you need to think about adding a cylinder to the equation. You can still keep the combi though.Combis are for flats and one bathroom houses why would you zone that? If you are fitting them to larger dwellings, which I don't think is right anyway, then the same rules apply and zoning a combi is the same as zoning a system boiler no difference at all.
The updated part L doc states that all dwellings now need a minimum of 2 heating zones contolled by a room stat apart form some bungalows and open plan dwellings ,e.g a 2 bed semi now needs to be zoned !New builds with a floor space over 150m2 must have this area split into 2 (zoned). There must be an independent means of control for each zone.
Why would it be not practical to use a combi? As long as the combi has been appropriately sized for the dwelling then this can be zoned. But if your dwelling is over 150m2 it is doubtful a standard combi will suffice.
Apologies TB. Miss-read your post slightly. A decent combi installed correctly is sufficient for your average household, but as you mention stepping up into two bathroom territory is pushing it.I said one bathroom properties. Properties over 150sqm are almost always going to have an ensuite and probably anadditional utility or wc. Adding cylinders to combis is ok but if you are using weather compensation you may well get conflicts with preheat controls etc. My view is if you require more hot water than one shower at a time combos are not the best solution
These regs are starting to kick the backside out of it! They are becoming pathetic.The updated part L doc states that all dwellings now need a minimum of 2 heating zones contolled by a room stat apart form some bungalows and open plan dwellings ,e.g a 2 bed semi now needs to be zoned !
maybe the guy who updated the regs has shares in a controls company??
on a normal combi install how much would be saved in energy compared to the extra cost of the install? The simple adjustment of a trv costs nothing.
its another way to send people into the arms of unregistered installers the more us rgi's have to fit the easier and more profitable it becomes for the un registered cowboys in the same way that raising tax on cigarettes and booze makes smuggling more profitableThanks for your responses guys, according to OFTEC technical, all installations (apart from some open plan) have needed to be zoned since oct 2010.
As a newbie I was unsure, but it seems nonsense to me as you are increasing system volume with extra pipework and also adding extra components the manufacture of which must also create polution.
Do the people dreaming up these regs actually fit systems
your basicly running a combi as a system boiler, just think of the heating flow and return as primary flow and returns to be run from the boiler to 2 , two ports.So would I be ok with a Time Clock, 2x 2 ports wired to room stats ? for Zoning a Combi
and for wiring them to the combi should I take the flexi's from the switched spur to the 2 zone valves, then from the zone valves to the room stats ??
not had to zone a combi before
Just a thought!
What about condensing combi's?
Many require a large unregulated rad in some part of the system to drop the return temperature the surface area of by pass circuit not being big enough. Bit of a nuisance really.
But if you zoned the system you would need an ungoverned rad in each circuit for it to condense properly. A bit more of a nuisance for the customer.
Reply to Zoning with a combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
