blinkinhek
My 'new' toilet did not come with any instructions.
I asked the 2 fitters (the one who installed it, and the second one who replaced the faulty pan) what the two buttons did. I was aware that this should operate a half-flush and a full flush, but did not know which button or which button combination should do what ....
I got 2 responses, from the first that "...the small button is only there to help the larger button pop out ... and no it wasn't a 2-button flush system since there was only one cable from the panel"
The second statement was "...you need to press both buttons together to get the larger flush"
The cistern and panel seem to correspond to a Macdee cistern and dual button panel (duo-compact cistern and front access fascia). The panel has one small button surrounded by a larger button.
I emailed Macdee ... and got zero response.
ps ... I cannot tell any difference in flush volumes between pressing the small button, pressing the larger button and pressing both buttons ... so maybe I have been short-changed on the cistern?
cheers!
Just pulled out instructions
Use 1 for a small poo 2
And if you have a poo and do'nt know what to do,go for the 2
Do 2 if you have a wee and follow through with a poo
If your not sure what hit the floor ,hit 2 as it maybe a poo
Use 1 if you do'nt need to wipe your bottom,always use 2 if all above is forgotten 😛
Hope this helps
The flushes should be the same,as said one will be longer than the other if syphon set up correctly
imho
what do you press if you know somethings come out - but didnt feel it ?
OP smaller button small flush
bigger button big flush
