Guys, I’m turning myself inside out here – Please help!
There are many similar discussions posted, but none with my exact symptoms.
Original shower / boiler combo working fine for 10 years, however recently when taking a shower, the water will shut off with a thud and pulse with significantly reduced flow. Issue occurs at random intervals during every shower. The problem is managed by slowly regulating the supply valve to approx 50%, if opened further or operated rapidly, flow drops and pulses.
Specs:
Boiler – Baxi Combi 105e
Shower – Originally Triton Alcor / Replaced recently with Triton Themes
Pipework - Copper 15mm / braded flexibles up to the shower body
Checks complete:
Annual boiler service IAW manual (burner and heat exchanger removed / injector clean / filters etc)
Replaced incoming scale inhibitor
Checked CW inlet / DHW / Flow regulator filters (all clear)
Water company have confirmed pressure / flow correct at the tap
New mixer shower fitted, thinking the issue could have been due to a faulty thermostatic valve.
New shower gives the same issue.
New shower body filters proven clear
New shower body existing check valves replaced with combined check valve / flow limiters, IAW manual
New shower head / hose fitted, issue present whether shower head if fitted or removed
Observations:
Central heating functioning correctly
Boiler clear of warnings / faults
Shower isolating valves are open fully
Braded flexible hoses have no twists
All other taps around the house work fine (even with maximum pressure drop and all taps operating at once)
All other taps provide hot water, even when operating rapidly
Boiler getting old, but other than this shower issue it functions correctly
I’ve now reached a dead end, and thinking of checking the flow regulator / flow priority assembly / flow priority micro switch? But before go changing more components, your thoughts are welcome?
This problem is driving me mad, all advice is appreciated
Andy
Specs:
Checks complete:
Observations:
Andy
