E
electron
High there Pipe Benders🙂
I've received in mail this lunch time a letter from British Gas re this boiler, informing me that the Manufacturer has stopped making some replacement parts.
How worrying should this be to me, as I've had the boiler since 1999, and throughout this period I've had the following parts replaced under contract:
Usual thermistors
PCB
Gas valve
All the above were associated with a faulty gas valve I hasten to add.
I know the gas valve is a Honeywell Part.
Replacement has also been carried out on the DHW Flow switch Diaphragm, which is incidetly now leaking slightly from the pin(probably O ring failure)
Could you please advise, or is it a ploy to get me to fork out for a dreaded condensing boiler.
Thanks in advance
Usual thermistors
PCB
Gas valve
Thanks in advance
