Spin32
Evening
I was hoping for a bit of advice for my Baxi Bahama 100 combi boiler. I realise its quite an old model and is around 12 years old but until recently it's been quite robust.
I do usually use a local plumber but unfortunately he is on holiday.
from last night the boiler stopped producing hot water after about 15seconds. The pressure is good and I have bled the entire radiator system. At the moment the only issue is with the hot water. The radiators are working fine.
The boiler fires ok as soon as the tap is turned on but turns off soon after. Only cold water is produced then. Turn the tap off then back on and it repeats this cycle.
we have also reset and turned off all power for a period to see if it clears any error.
any suggestions would be grateful. My usual plumber has suggested from what I have told him that it could be the Diverter Valve Head as the pump must be working if the heating is
Thankyou
