gastec
Hello all the problem with it is it will not heat the water when running a bath, it fires up but no hot water, the heating works fine and other hot taps get hot but the temperture some times fluxuates. I have changed the plate heat ex, diverter cartridge and actuator. Any ideas?? Thanks
Is there a mixer shower fitted in the bathroom, could be faulty non return valves or none fitted. Shower could be feeding cold into the hot supply. Isolate the cold to the boiler and see if the water stops running from the hot taps, if water still coming out of hot taps you should be able to hear water passing through the mixer valve.
