Baxi Duo Tec 28 Hot Water Issue
View the thread, titled "Baxi Duo Tec 28 Hot Water Issue" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Baxi Duo Tec 28 Hot Water Issue.
Hi, I have a Nazi duo tec 28. I’m having an issue with my hot water.
If the CH is on, and I turn on the hot water I get warm/tepid water provided the HW temperature dial is set about 3o’clock.
If it’s set any higher, I get an E28 fault, and my water goes cold. If the CH is not on and I demand HW I get the E28 fault almost straight away.
The condense and flue can’t be blocked, otherwise I would have no CH. The flue and hot water thermistors have both been changed.
It’s recently had a new gas valve fitted. Baxi won’t touch it due to having to work on loft ladders.
Any help would be greatly appreciated.
Thanks,
Geoff
Reply to the thread, titled "Baxi Duo Tec 28 Hot Water Issue" which is posted in UK Plumbers Forums on Plumbers Forums.
geoffjb1972,
Deleted member 120897,
