Pottsy44
Hi guys,
im a bit stuck on the diagnosis of the above boiler, called out to the property customer complaining of no hot water, heating works fine. Pulled the cover off and noticed a small leak that had crusted up around the hot water sensor in the diverted valve so changed this confidently.....however!!
The problem is still there, heating works fine, on demand for hot water boiler switches over (front LEDs indicate) boiler fires, temperature gauge rises to around 70 degrees as water flows out of tap....cold?
My thinking is the cartridge inside the diverted valve is sticking, so I've removed the motorised head....hey presto water flows hot!!
This is is where my confusion begins, is the cartridge the problem or the motorised head?
Any help is thankfully received
Cheers Jason
This plumbing forum will not provide advice to anybody with regards to boiler repairs or any other form of gas plumbing without you first providing us with your Gas Safe Registration number in a thread - for very obvious reasons. If you're not qualified to touch gas, you should stay well clear of trying to!
completed my asc reassessment last week so until the Certs come back I guess I'm not qualified to touch it? Hopefully customer will wait a week or so
But thanks for your help
