abc_plumb
Hi Guys
Need some advise here.
Went to a property today which had a Biasi Riva Plus He M296.28SM/C.
The problem is the burner goes off after 2 mins then back on again on hot water mode.
When the burner goes off, the 1st (far left) green led is flashing the middle red led is flashing and the (far right) green led is solid.
The manual suggests a faulty APR.
but after 19seconds the boiler fires back up for couple of minutes, and goes through the same cycle again.
The DHW plate is clean, and the gas pressures are good.
When I took the combustion chamber off the burner didn't go off.
This is all making me think its the APS, but the above fault doesn't happen on heating, which is putting me off.
Any experts out there on this boiler?
Your help is appreciated.
