F
Flanners
Can anyone please recommend a boiler around (28kw) without a pump over run. Open vent conventional boiler!
Why on earth would you want to put a new boiler in rigged up to an open vent? Why not a system boiler?
Why so supprised? You don't need to change every system to a sealed system when you change a boiler?
you have the baxi solo,dont know what other alternatives there are,i can see you needing a open vent if a duel system set up or if pipe work in floors obviously system set up a lot better
I have a Gledhill boiler mate 2 which I have to run with this boiler. It has a built in 4minute pump over run and cannot be used in conjunction with another boiler with pump overrun as this would take to much heat from the thermal store. I know the boiler only needs to be sized to accomodate this thermal store but want to put in a boiler with a higher output to accomodate an unvented cylinder when the boiler mate packs in.
Hece the question.
well a baxi solo or main 30 heat only does not need a pump over run i will be honest i only fit baxis or potterton the solos not my favorite boiler,but i dont know of any alternatives
Quoted to remove cylinder and boiler.
Advised to fit Vaillant 630 Eco Tec, S-Plan, 210ltr Ultrasteel with a powerflush and magnaclean.
Just an update!
ive got a boiler mate running with a system bvoiler i just ripped out all the boiler mate electrics and run the boiler via the cylinder stat flow switch on main stops the heating pump when ho****er calls probably totally illegal nowdays but its worked for 20 years now
we used to be able to think for our selves that was where skill came in
I agree steve!
No manufacturer would guarantee there boiler unless the pump over-run was connected so i was over a barrel if I wanted to provide the best service and after sale service!!!
I agree steve!
As gasman said, the Baxi solo he range does not need a pump over run due to its large heat exchanger. This does not effect the warranty as Baxi state this.
