bluesky
We are going to install a boiler on a conservatory wall. it is a 100mm brick wall. the mortar looks in good condition. the only thing worries me is that the wall only support a light plastic roof, the foundation might be only 300mm brick foundation, do you guys think the boiler can be put on this wall? is there any guidance to value the stability of wall?
many thanks
Yup as above your ok to use that wall. If you install on an internal wall most of the time (uless new builds) your hanging on a breeze wall, so there isnt much difference to your wall.
Good luck with your install.
Want to try putting a 120kg oil boiler on the wall with 2" clearance either side. 🙂 As stated above your wall will be fine.
