Pollitt
Hi all,
I have just moved into property with glow-worm space-saver system boiler. There is a hot water cyclinder with feeder tank above. Their was once a immersion heater on top of cylinder that is now not wired. There is control switch in kitchen for this not working. I didn't want to use immersion heater to heat up water as I've heard this can be expensive method. My problem is there is a room star in hall and a danfoss 103 control unit in kitchen. This danfoss clock is an old type with timer,off or constant settings. It has a,b,c & d setting for timer. Now I don't have problem with water being heated when boiler is heating house. My problem comes when wanting hot water only when summer comes. Now if u turn stat down and put clock on constant boiler stops firing when temp reached. I also can't find thermostat on cylinder, but could be present at rear. Was wondering how to select water only without heating. I thought systems of this type contained control zone valves to single out demand for boiler. Can't find switch anywhere.
Sny advice would be greatly appreciated.
thanks 🙂
thanks 🙂
