Plumber1987
I am working at a house in the countryside and the mains pressure is only a trickle. I was hoping somebody might have an idea on how to solve this problem at a very low cost.
Hi Plumber1987 and welcome to the forum.
There are a couple of pumps that you can put on the incoming main - Salamander are promoting their Homeboost at the moment, but they aren't cheap, and it is set to max out at 12 litres/min to meet water regs.
All other solutions that I am aware of are more expensive than that, although they may provide better performance.
If there was a very low cost solution, no-one would have a flow-rate problem!
Here you go.
No noisy pumps or mechanical faliures, fantastic flow rates, and no tanks of water open to atmosphere.
[DLMURL]http://www.twsuk.com/media/data_sheet_mainsboost.pdf[/DLMURL]
