streetmj01
I'd appreciate any advice on this situation.
We have a very old Chaffoteaux Britony II multipoint water heater fitted under the kitchen sink. It is working fine, although recently we have had to replace 2 fibre washers after the inlets leaked. The first was replaced by a local plumber, the second I managed to replace myself before the plumber arrived. When he did arrive we discussed a replacement. As we have a fairly recently replaced warm air system we just wanted a like for like replacement for the multipoint. Regulations introduced since ours was installed make it seem impracticable with regard to positioning. An alternative was suggested. This was a combi boiler with just one small radiator. Nothing further was done but as winter draws on and the heater pilot light has blown out a few times recently I have been thinking about this again. It may be as simple as a thermocouple but it can’t last forever.
Is such a replacement a solution? Advice/suggestions welcome.
You can get fan flued water heaters so no need for a pilot I'd contact your gsr engineer to discuss more
Upvote 0
Have a look at [DLMURL="http://www.rinnaiuk.com/rinn/index.php?id=31"]Gas Hot Water Heaters, instantaneous gas water heaters, domestic central heating - Rinnai UK[/DLMURL] to get an idea of what is available now.
Upvote 0
I'd be inclined to get your water heater serviced and a couple of parts renewed.
The Britony is a great and reliable piece of kit.
Upvote 0
Pilot fault on those very common, as said, get it serviced properly and it will do you fine.
Many thanks for advice, especially re. servicing our existing heater. After a quotes of £1100 to £1700 for new multipoint to combi + 1 radiator we asked local plumbers for quotes/advice. Only one got back to me and did a clean/service for £30. Blocked jet as diagnosed on this advice forum. WONDERFUL!!!!!! Thanks again to all who took the trouble to reply.
Upvote 0
