squeakyclean
If possible I would like some advice regarding a fault with a Ferroli Falcon 2 combi boiler I have fitted in my home and would appreciate it if you could help.
The Boiler is not firing up when I either open the hot water tap or turn on the central heating.
With the hot water tap open the boiler will always fire up only when the room sealed cover is released and will work perfectly with this cover removed. As soon as the room sealed cover is refitted the boiler will not fire.
Please could you tell me if this fault may relate to the air pressure switch? The fault finding in the manual seems to point to this, but I am struggling to understand why the boiler only fires up with the room sealed cover removed.
Any advice would be much appreciated.
