no you cannot😱😕Just a query. Can you legally disconnect a bayonet cooker connection and reconnect with a new cooker without being Gas Safe?(I'm only refering if it's a straight in/out swap). You have to also install a stability chain don't you?
however it does not give them exception to replace/refit
Where does it state in regs or BS that this cannot be done by the end user?
An exception to this requirement is in
circumstances where the disconnection of the domestic appliance does not require the
use of a tool. For example, a cooker or an outside barbeque is usually fitted with a
flexible connection and a self-closing valve. These may be disconnected by the user for
cleaning and storage respectively.
And for reconnection?
I'll agree with you on that one😉You need to get a gas safe plumber in officially
how would you test this?with a match or maybe washing up liquid🙄If its a self sealing/closing valve then you can take it off and see it yourself that gas will not flow. Thats why its called self sealing valve
Absolutely no way at all.If you do this then you are breaking the law.The only people that can do this are Gas Safe registered engineers.😕Just a query. Can you legally disconnect a bayonet cooker connection and reconnect with a new cooker without being Gas Safe?(I'm only refering if it's a straight in/out swap). You have to also install a stability chain don't you?
not untill something goes wrong,how would you prove you had followed the correct procedures?tickles me when peeps think messing around with a potential time bomb is not a problem.save some dollar,let them carry on😛I dont understand all these responces? Surely all you Gas Safe registered Engineers must know you do NOT need to hold any gas qualifications or tickets to connect a bayonet gas fitting?
mark, its a just a big hoohaa, good reading though
