That's coz I'm a cool dude!Always all copper with me.
Connecting to the pump hoses neater and no strain on them with copper offsets.
You made it awkward for yourself with the outlet horizontal pipes level a bit close to pump to connect easily to.
I like the use of lever valves
I tell you what Dave, on this one there's a 750mm void between ground floor & first (bungalow converted to hoose).Nice clean install.
Personally I'd have put the pump on a paving slab and cut the noise by half too. 😉
I made a hand drill from 15mm copper cut at 45 deg to penetrate ceiling below (rather than SMASH a hole through). 🙂🙂
Bit of carpet underlay under the slab and it’s veritably peaceful
Will do on all future installs Dave, thanks to Riley and Best as well. 🙂The thick slab reduces the vibration noise transmission by an extraordinary amount. The bigger the slab the better.
