Hi Guys, I have just removed an unused shower from my house and have exposed the water pipe as can be seen in the attached photos. My question is "do I have to drain the whole house to then be able to cut the pipes where they are" or is there now a way of cutting the pipes and sealing them where they are ?. They will never be used again and will be concealed in the wall for good. I would appreciate any advice regarding this matter.
As guys above have said you will need to trace where the feeds come from and cap near as possible to the supply, it's not recommended to cap off supplies in the wall leaving a dead legs , the feeds will need isolating to do this either isolating the mains water supply and draining Or if you have inline valves to the shower use those . Kop
