M
marcel808
hi
a week ago, we started to see problems with the central heating. When the central heating switches on, nothing happens. When the hot water is switched on, both hot water and central heating start working.
I assumed it was a problem with the diverter valve (we have a Drayton MAI/679-3 mid position diverter).
I changed the front electrical part (the actuator), I havent touched the water diverter valve because it seems to turn easily.
After changing the actuator, no change, exactly the same results.
Is really confusing me 🙂 If I check the voltages, when the hot water on signal goes to 240v, that connects straight to the orange wire (boiler on I assume) and the boiler starts. But when the white (central heating on I assume) has 240v, the orange (boiler on I assume) is 0v. Does the actuator look for the white wire 240v, turn the motor then set the orange wire to 240v?
Even when I take the actuator off the valve, the motor cannot move to just central heating. See attached photo, even using the manual level on the side of the actuator, it can only move between W (water) and M (both water and heating). I cannot ever get it to turn to H (just central heating). Its a brand new actuator, doing exactly the same as the old actuator I took off. I'm really confused 🙂
many thanks for any advice
