M
Mikeycollins
Since saturday, each time I have switched the boiler on it has failed to stay lit without the reset button being pressed. Tonight I had to press it about 10 times before the boiler staed ignited. Once started it seems to shut on and off normally (so far).
When switched on, the boiler does light, but then immediately flames out. I have noticed that there is a small amount of water at the base of the exterior overflow pipe. At first I thought that this might be part of the problem but having read some more I have discovered that this could be part of the condensing process. The boiler is operating at 1.5 bar so it shouldn't be due to the expansion safety valve. Any ideas to what may be wrong?
its a ferroli sadly its rubbish as said get someone to look at it
Like a scrap merchant 😱
Sorry,could not resist,hope you get sorted ok but will need a qualified person to look at it
LOL,his yard will be full of ferrolis,ideals,kestons ravenheaps etc
