davegirtch
Recently the pressure in our boiler dropped to zero. I re pressurised the system and removed the fill loop. checking the pressure vessel it was also at zero. I pressurised this to 1 bar, which put the system pressure up to 2 bar. dropping the system pressure back down to 1.5 all seemed ok. Turning the boiler on caused system pressure to rise over 2.5 bar and the pressure relief cut in. system pressure wnet to 1.5 and then began to rise to 2.5 again. I turned the boiler off and the pressure dropped to zero. turning the boiler on and re pressurising the system goes through this same cycle of too high pressure then cooling down to zero. I have drained and refilled the boiler and bled all the rads but to no avail. Can anyone help please? is the pressure vessel faulty?
