Hi
I recently went to a house and fitted a new bath mixer tap and a new washbasin mixer tap. All went well and no problem. However the client had been complaining about noise coming from the hot water taps, this noise happens occasionally but when it does the noise is quite deafening. It is a sort of rubbing grinding noise.
I thought originally that it might be water hammer or pipes not being secure. The place is a small ground floor flat with a gravity hot water supply fed by a Fortic combination tank. The pipes look secure and I think water hammer is unlikely because there is little pressure on the hot water.
I also thought by changing the taps this might help but the noise happened again when I was testing the system. The noise stops immediately as soon as you turn the mixer to cold water.
Any thoughts or ideas from anyone??
Paul
Paul
