Davis
Have an issue with heating/hot water system. It's conventional system with potterton precision boiler (3 years old) and expansion tank in loft. Issue is that heating and hot water run fine independently but when both are scheduled to be on at the same time, the heating works but the hot water does not. If I turn the heating off then water seems to heat up quickly. I've tried to replace the 3 way valve head unit as this was cause of similar problem about 5 years ago albeit on the old boiler (but other way round i.e. no heating).
Am currently running the timer on different schedules so there is water in the tank for showers etc when the heating is not on but would appreciate any advice on what to look for.
