N
Novice Bob
I recently removed all my radiators, manually flushed them through and refitted them.
I refilled, bled and balanced the system.
All rads now get good and hot and the boiler sounds fine.
However, when I select hot water, the pipes by the h/water cylinder make a squelching/squirting sound and the boiler sounds like a boiling kettle and seems to go off after a few minutes. When I deselect h/water, the motorised valve amkes a bit of a rattle when it turns off. None of this happened before.
Any ideas as to what's wrong?
Yes,
You have no flow through the boiler when you select hot water.
I wouldn't keep switching the boiler to hot water and let the boiler kettle like that to many times.
Unless of course you want expensive repairs or a boiler replacement.
Post and add on here and get someone in.
Many thanks for your reply oz-plumber, I will definitely heed your advice.
Out of curiosity, what could have caused the non-flow (on hot water) situation?
You say you have a Hw cylinder, is there any sort of a vent on it? On the cylinder primary circuit, the same pipework where the motorised valve is on?
