Morning chaps
Had a call out to the above boiler yesterday with no hot water. C/H working fine
Popped the front cover off, run the hot tap, internal pipe work from burner to H/W heat ex was hot but the H/W heat ex was cold.
Burner fires up as should, fan runs as should & showing NO fault codes.
Was thinking blocked H/W heat ex but the flow at all outlets is fine. Could it still be a blocked heat ex?
Thanks peeps
Thanks peeps
