Hey guys . I'm looking for a bit of advice. I have a job to do to a regular customer who's moved house in the country. It has a private well supply and at the minute there are 3 storage tanks in the attic filling the usual gravity system. It's a decent size property and he is set on a combi boiler . I've tried talking him into pressurise HW and system boiler but he's adimant he wants a combi ...... I'm planning fitting an ideal vogue 40 but my issues are his incoming main standing pressure is nearly 1.5bar soon as you open tap that drops drastically. It's around 13lpm. Now I'm looking to boost the water to the combi boiler for the hot water as well as boost the main going to all other outlets . I spoke to grundfoss today about there home boost which is combination of a slave tank and pump on the incoming main which is usable for combis and boost the pressure to 3bar . On previous jobs I've fitted the UPA 15/90 but that's no good for what I need . There are 2 bathrooms in the property and the usual utilities. I'm looking to see what you guys might use in this situation. Some pumps I'm looking at cannot be put onto mains so they need storage tanks so I'm just not sure what set up to go with . Also in the property is 2 electric showers so they will be replaced with thermostatic mixers so water need to be balanced .
Any of you guys any ideas or previous experience with this type of set up thanks in advance chaps...
