plumbingdazman
Hi everyone,
I replaced an internal plastic stopcock for a new brass one last night as the internal one had been leaking. i turned the external stopcock off while i was working on the internal one, after i finished i turned the external one on again to check that there were no leaks (which there werent). On way out of property i checked the external one was open all the way and to my suprise the handle was slightly submerged in water, so now i believe the external stopcock is leaking.
Now what i want to know is, is this a job for the water board as its on the main supply i suppose and will the customer be charged for having this fixed.
I cant understand why it started leaking.
Any ideas/suggestions would be helpful
Darren
Re: Leaking External stopcock
If its outside your boundary then water board should fix it.
Tell them you have a leak and it needs doing to repair,that way they come out quicker,can be a long wait,if you just ring them up requesting street valve repaired
imho
