Light Commercial Boiler Reviews
View the thread, titled "Light Commercial Boiler Reviews" which is posted in Boiler Advice Forum on UK Plumbers Forums.
T
tm plumbing
I've been asked to quote for a replacement 50kw boiler in a welfare club & notice Vaillant and Viessmann do 46kw & 45kw models respectively. Has anyone fitted any of these sizes & any reviews much appreciated.
Trev
Viessmann commercial are horrible. Worcester Bosch have taken over Buderus and rebadged the GB162. Lovely boiler. Gets my vote every time.
On a similar note ferroli are sneaking out commercials under the Lamborghini badge. Give them a steer too.
Why one large TM? Can't you go for two 26kW on a LLH ?
Should still be able to get it of a U6 a John ? as its only light com LOL
No reason Chris I've not seen existing setup yet so keeping an open mind, two might work better depending on how they use it & their HW demands. I've not fitted a lot of 40+kW so was just looking for reviews. I did fit a Keston a few years back in a church but believe they are high maintenance. If it's the one big one it's looking like the Vaillant but I'll call my Worcester rep for a heads up too that's if I get the job ;-)
Two logics systems on a LLH or two heat only on a cascade. If it's a cascade make sure u have good filtration .
Anyone would think I worked for Remeha but I think the Quinta pro 65kw would serve you we'll. nice compact wall mounted. 900 by 500by 500 mm.
Had a look at this the other day & 2 Worcester Cdi 30 kw with a low loss header looks the way forward. Also 2 250L cylinders. It has 3 heating zones plus HW.
My dilemma is whether to introduce pressure to the malleable iron or not.
Anyone used a low loss header on an open vent system as I've only ever seen them used on sealed systems.
If it is an old dirty O/V system might be an idea to leave it that way but I understand some are using large plate heat exchanges instead of LLH that way new boilers with small water ways can be on sealed system while old system remains open.
Although risk of plate blocking they are a dam-site cheaper than a boiler or two (spare could be left on site ready).
Not done personally just heard about, would be interested to here from anyone that has.
Just fit a 45kw vaillant with a circuit splitting plate hex. worked a treat..boiler seems good but only been in a month..we usually fit ATAG's but controls aren't as user friendly personally speaking..
We all know you take a chance putting and new boiler on an old system, the plate is a good idea but it means two pump if you have two boiler that's three pumps,the nice thing about a plate is you can strip it down, never ever fit a solid one, a plate will bump he cost up a bit. A tube one as Ermi says will do also but not many around make them any more, made to order perhaps, you could suck it and see mag-filters and mesh filter.
Quinta for me. Simple little boiler. Well built never had issues with the well maintained ones. Well apart from a h/e that corroded. But that's one. Never got along with Atag myself. Had too many bad experiences with non user friendly controls. But they obviously may have changed now.
i would go with the plate exchangers aswell. we fit them on all our systems where we connect to existing systems. If you did want to seal the existing side and are worried about pressurising the steel pipework, you could look at a spill and fill system.
Spill & fill system ???? more info please :confused5:
Chris,
I think he means the use of a spill back tank, now not used, I have only seen a few in my 55 years in the trade, usually a large tank on the plant room floor 1/2 full of water, plastic balls floating on the water, and a spill back PRV when the water in the system expand it spills back into the tank, when the system cools down the pressure set puts the water back into the system.
Normally on a big job with a high head that won't support a membrane in an expansion vessel, the last one I worked on was about 10 floors offices, about 4.5 Bar system pressure with steel tube boiler rated at 6.5 bar.
PS Usually large volume of expansion required
Chris,
Well you learn something new every day !! Thanks for that happyflyer.
I think that is what I will miss most, as of next week I will no longer work in the plumbing industry. (some say I never did)
Still there will be plenty of new learning to be done!
If you lot will allow it, an ageing ex-plumber may still stick his head in the arms every now & then for a swiffty & chew the fat.
Reply to the thread, titled "Light Commercial Boiler Reviews" which is posted in Boiler Advice Forum on Plumbers Forums.
tm plumbing,
tm plumbing,
