M
midge
A colleague has an older atmospheric burner fired gas boiler which although working fine is near the end of its life.
The problem is that the meter is 400 metres away down a long drive, piped in 2" steel to the house. Although there is 23mbar at the meter outlet, the appliance inlet pressure is 17mbar.
No one seems to want to change the boiler as it's below 19mbar. Obviously it has been wrong since being installed 20 years ago, but he's had a figure of in excess of £20,000 to trench and replace the 2" with larger PE pipe which is out of the question.
Is there any modern boiler range which can be suitably installed? as otherwise he can't see a way out other then oil or LPG.
