A
agganesh
Few weeks back I had a water leak in the combi boiler Worchester 28i so I called e-on service care engineers to fix it who came and did it.
Since then I have problem with the hot water supply in all the taps and showers at home. When I turn the tap less than a half way I get good hot water (45 degree) but I turn it more it comes very lukewarm. The engineeers came again and confirmed the boiler works ok as it raises the water temperature from 5 degree to 45 degree (when turns the tap half way). They said that the problem is with the incoming water being too cold and asked me to complain with United Utilities - the water company. When I contacted them they didn't want to take any responsibility for the water tempeature as they don't guarantee it but they confirmed the water temperature can be expected around 17 degree.
I got full cover with e-on including plumbing but their plumbers said the problem cannot be down to plumbing. Now I am not sure what could be the problem and who can fix it. Anyone have idea? Thanks for reading.
What is ov bar? Is it the dial on the boiler which shows the pressure?
I will turn the main to reduce the cold water supply (so it affects whole house not just the boiler) and see how it goes. I will let you know tonight or in the morning. Thanks.
the 35 degrees temp rise is at the boilers max flow rate eg 10 litres a min 35 rise . get a bucket and open the tap for a min then empty the bucket with a measuring jug to see how many litres this is your flow per min then test the temp .
what is your mains pressure in terms ov bar try turning your mains down a quater of a turn or so
I turn it down 1/3 I guess and can feel the difference still far from what it used to be. The downside is the cold water stops completely in upstair bath if I open a tap in downstairs.
Open the tap as much as possible where I get maximum temp and filled up the bucket. It was just 5.5 litres a min. This too after closing down the main 1/3 as another poster suggested earlier.
boiler should give 40 degree rise in water temp at 10 litres a min - so try and get the tap set so you get that and take a tmep reading of the water temp - if this is 40 above cold water temp in the boiler is ok
Thanks. will try but don't have a thermometer so need to buy one.
Got a call from e-on people and now the engineer last visited says the problem could be down to Heat Exchanger which is not covered in the e-on service care agreement. I am not sure how he changed his decision from "unusually low temp cold water" coming through to Heat Exchanger problem. I have escalated this issue to the management now and am sure will get a call tomorrow or so.
Now I lost faith on the e-on engineers, coz couple of them visited so far, the first one found "no problem" and when complained they sent another one who confirmed the problem and it was due to the incoming water being too cold.
In mean time please pass me on your suggestions so that I can understand what's going on with the boiler.
if it is your heat exchanger it could be sludge restricting the flow of hot water through it thus not getting up to temprature so you will need a new 1 hope this helps
you would need a gas safe bloke in to sort that out as for price it depends on what kind of heat exchanger it is
Thanks jam1979 but as you can see from my earlier postings, I cannot trust the e-on engineers anymore as they couldn't find the exact problem. They have been telling different reasons everytime so before I am spending big money to fix this issue I would like to confirm myself if the problem is with the heat exchanger or not.
