J
jamiepm
Hi all,
Looking for some guidance on what to do to fix my boiler. I've started to notice that hot water water has become intermitent in supply of hot water, this has been going on for a few months now. And at present the boiler is switched to CH & DWH mode, however on reading some of the info on the internet. I tried the following, I switched my bolier to DWH only and set the temp stat to max, then turned on the hot tap fully, however the burner light didn't illuminate and likewise no burner equalled no hot water!!. I then repeated the test and put the boiler into CH & DWH mode and opened the hot tap fully and again no burner illumination/fire up, however if I reduce the hot water tap flow it bursts into life and then I'm able to open the hot tap fully and get hot water (sounds like I'm jump starting the system!). Any takers on what is bust??
Cheers Jamie
Cheers Jamie
