J
Jason Saunders
Hi i am constantly getting noise from my combi boiler its a ratting when the boiler is not in use it stops when i switch off the cold water feed at the stopcock.
I have tried shock arresters. Could fluctuating water pressure be rattling something inside the boiler?
Would an expansion tank help?
any ideas would be gratefully received
jason
Sounds like the water mains is getting through to the boiler.
You need to get a qualified engineer to sort it & service it.
And this forum cannot give out any advice on repairs if it is a gas combi boiler.
Hi thanks for for reply it is 5 years old it has been serviced yearly and been looked at for this issue many times.
you say water mains is getting through to the boiler can u clarify surly this is necessary for the shower and hot water taps
many thanks
jason
