A
akwoody2
Hello,
Im after a little help.
Im a novice at plumbing, all i have done regarding plumbing is re-fitted my bathroom.
At the weekend i decided to change my radiators. I have a conventional system in my house, i switched of the water supply to my tank and switched of my boiler, drained the system, changed the radiators and refilled with no leaks.
I have bleed all the radiators and all are getting hot.
The problem i have is when the hot water kicks in, there is a lot of wooshing and water running noised, almost sounding like large trickles. This wasn't happening before i drained the heating.
How do i stop it?
Many thanks
Does the boiler bang? Is the system conventional or a combi-boiler.
It does sound to me that there is still air in the system. Try shutting all the radiators off at both sides. Then Intoduce one at a time by opening the feed side (side with adjustable valve on it). Each time you introduce a radiator bleed about half a bucket of water from it. Once they are all bled open the lock shields up (other end of radiator) and balance the system.
Edit sorry I see its a conventional system. Near the tank there should be a vertical pipe with a bleed on top. Try bleeding this too. I modified my own system and since have problems bleeding first time. I might have to bleed this 3 or 4 times before all the air is out.
Ok ill give i a go, its a conventional system
If your still having trouble try turning off the boiler and turn on the hot water and heating at the controller. This means all the systems will be connected together. I was taught not to bleed with a pump running but I find it makes little difference! If anything the pump pressure will move airlocks.
This way all the air should make its way around the system till it reaches a point where it can be bled out.
Don't despair bleeding can be a work of art on old systems if they are not filled properly. Even if they are filled properly air can be in there and they need a secondary bleed!
