W
washer
A year ago I moved into a property which has an oil boiler, and I am now in the fustrating position with it developing an intermittant fault, although I am GSR and am more than happy fault finding on gas boilers, I do not know the sequence of operation on oil boilers.
If anyone could perhaps give me a couple a pointers, I would appreciate it, I stress that I will only fault find with a multimeter, and if any parts need replacing, I will get the bloke who serviced it last to fit if needed.
The boiler is a Worcester Danesmoor 12/14.
All controls are working fine, pump is running but only circulating cold water, no lockout light on the boiler, and increasing the boiler stat does nothing.
The only way it will restart, is turning the fuse spur off and then turning on again.
Happens about every couple of weeks, so of course if I did get an OFTEC engineer to have a look, you can guarantee it will work fine.
Cheers
Cheers
