armyash
Subscribed
Customer has sent me this picture.
He wants it replaced with something similar.
Is there a big difference between 3kw or 7kw?
Triton Handwash - Search Results | NoLinkingToThis
the old 7&8.5 kw showers were always wired in 6mm so a 7kw hand wash unit should be no different remember the days we could wire up and connect into board ourselves ?..brum
<Cue "Hovis music" >
<Puts on fake yorkshire accent>
I remember selling 4mm cable for the cheapskates who were putting in 6kw electric water heaters or showers. I don't know if it was legal, but it used to happen in the 80s.
<returns to 21st century>
I agree these water heaters are carp. First time I got sent to one, the flow was so poor I thought it was broken. One of the lads said to me it's not broken they are just carp.
The installation method of the cable effects it's size a lot. The calculations are a pain, most sparks put in 10mm for showers as a rule of thumb.
That's useful, I didn't know sparkies used any rules at all, let alone a rule of thumb, now were are my regulation to find that rule............here it is stone age caveman regs BC 20,000, the rule of thumb
"if your cave is cold light a fire, current guidelines suggest that dry wood burns best, but you must read rule number 008 "rule of thumb" to ensure a safe installation"
Rule 008 "suck your thumb and hold into wind if the thumb goes cold on the cave entrance side that indicates a prevailing wind from outside to inside and it will blow smoke into the cave, do not light"
