A
allan
I have Potterton Gold HE24 combi boiler. It has recently started to have a problem where the hot water will go cold after a few seconds of running and getting warm later , the water in the kitchen is fine is hot enough, but in the bathroom it getting cold,warm,cold again , the bathroom is just 3meter from the boiler .
the other issue i have the pressure of the boiler dropping down to zero after one hour , and when i fill it with water till 1.2 bars , it dropping again ...
The gas engineer he cleaned and washed the heat exchanger two times but i still have a problem ...
If i put a new heat exchanger will solve the problem ? what about the pressure problem ?
Thanks in advance
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
[DLMURL="http://www.co-gassafety.co.uk/deaths.html"]CO Gas Safety[/DLMURL]
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
